Originally Posted by P-bod
If anyone is still looking and really wants to keep the factory radio, this worked for me.
1) Remove radio. Be careful not to break the dash bezel (experience).
2) Disassemble radio down to its component level: the face plate, front circuit board, CD player, cassette deck, main circuit board, housing. Sorry I didn't take good pictures of this part. You'll need a small nut driver. Take your time. The front board simply pulls away from the main board. The tape deck has a ribbon cable that will come loose. The CD fits into a raised connector on the main board.
3) On the main board, there was a component that had a broken solder joint (see pics). I re-soldered that connection circled in red which fixed the problem.
The broken solder joint was extremely hard to find. Only after being suspicious of this part was I able to confirm the broken joint by placing it under a microscope and gently lifting it with a small pic to see that it was in fact broken.
I have no idea if this is the common failure point of this vintage radio, but it was for mine. Good luck!
well, thanks again , from me now, 2 years after the fact ! just bought our 00 4Runner a few months back, and am in the process of loving it up ! I love getting all the original features working as new, plus a little careful hotrodding.
the exact same lug was cold soldered in our radio. lighting works ! took 20 minutes, thanks to great instructions. cheers !
