Originally Posted by 4RMDNA
Hi, I have a 2020 4Runner SR5 4WD. I did my oil change at 5500 a few days ago and I'm having issues with reading the oil level. The level keeps showing that it is overfilled (about 2-3 cm above the second dot). I've read online about how others are having issues as well. I used mobil 1 so it is very clear which doesn't help obviously. I put in the full 6.6 Qt after draining everything. Do you have any advice on what I should do to get an accurate reading? Should I drain some of it out? Thank you!
I did the same thing with my 2005. Had to get underneath and drain off a quart or so.
Important thing is to change every 5000 miles with right stuff. I like conventional. Tried synthetic. Just a waste of money IMO. Conventional is better IMO. 10,000 / 20000 mile oil changes and you get “mud” in your crank case!
