Originally Posted by blairracd
I currently have 890s and am wanting more lift. I have a 99, so I only ended up getting around 2''. I also plan to add a rear tire carrier bumper with a full size (285/75/16) spare very soon, and definitely don't want any sagging.
Should I just add spacers? I already have a 10mm spacer on each side. Should I get air bags? Should I move to another spring? Maybe Toytec Superflex?
Who has done something similar -- and what are your words of wisdom?
Bumper will (most likely) be a True North Fab w/ the full swingout.
I prefer Airbags. You can air up a bit to increase the spring rate to match your load. I always felt like the Heavy Duty springs were overkill unless you have an extra 500lbs on the back of your rig all the time.
