View Single Post
Old 01-06-2021, 02:09 PM
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
Try the OEM nuts for the top plate, you'll find they are about an 1/8" shorter than the aftermarket hardware and better quality, and the aftermarket Top Plates have a lil more thread, you should be fine without pressing new studs out and in, and it will look safe/proper capturing all the threads on the nut, although not necessary technically.
Malcolm99 is offline   Reply With QuoteReply With Quote
