Originally Posted by kvincef
my icon reservoirs had to be mounted using the non-existant threaded swaybar mounts. the holes for the sway bar mount are there but they are just holes, no threads. I drilled them out abit bigger and used rivnuts.
you also have to cut off a bracket covering the KDSS lines on one side, not a big deal because it gets covered reservoir bracket afterwards.
that's exactly what I need to do with my King reservoirs. They are mounted horizontally now because of KDSS but it causes quite serious tire rubbing agains reservoirs at full lock.
But looking at your picture I'm wondering how you regrease bushings on your Total Chaos UCA? Looks like you need to remove the reservoirs and the mounting brackets every time you do the service?
