Originally Posted by PatronT4R
Yes the mounting is tight with no air leaks. Do you have any pictures of how you wired it? The way I wired it was exactly the same as the factory speaker I replaced.
I would fact check this:
the factory system should be wired for working with a 2ohm load from the factory sub/amp combo. It seems to me that it may be wired up with two separate channels going to the sub, each with a 2ohm impedance... I don't know what the factory circuit for the factory sub looks like because I didn't use the factory amp...
Here is picture of how mine is wired up. I bought the 2ohm DVC version of this sub so that I would be able to wire it for a 4ohm load so the I wouldn't be overdriving the sub from the amp with to much output (250w RMS vs 150w RMS):
