I went with Beck/Arnley, the install was actually pretty simple. If you stick a piece of 1/4" angle iron on each side of the hub so that the 4 bolts push against the outer hub when loosened, it pushes it right out quite easily. I also like how the bottom swing arm unbolts without pulling the ball joint. I also replaced the dust shield while in there as there was nothing left to it. Pisser is that the old bearing appears that it was not bad, it looked fine when I separated it with my press and I still have the noise. Contemplating doing just the bearing on the other side as maybe that's where the noise is coming from. I hope it's not the front diff but I bought gear oil today for that.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
