Originally Posted by AuSeeker
I'm not sure about compatibility, but I would start my research by comparing part numbers for various components, such as engine ECM, wiring harnesses/schematics, etc., if I'm not mistaken the early 4th gens use a different Bus/Can protocol so I'm guessing the ECM would have to be swapped, and the wiring harnesses are most likely different so either they would have to be swapped or adapters made.
That being said the savage yard type websites should give the choice of compatible engine year models, which should be much easier to find the answer to your question.
Thanks for the info. I'll call BOW in NH as they are who I normally use for used motors and transmissions. Sometimes they don't want to do any cross reference for you though. We had a same year/model where the flex plate was different... It didn't get noticed or swapped before install (shame on me) and it didn't fit so it got done twice. Trying to avoid that kind of thing for sure.
