View Single Post
Old 01-10-2021, 06:05 PM
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
If your going through all the trouble to remove the intake plenum and do intake gaskets, you might aswell do the VC gaskets, half moons and cam plugs, I guess you could reuse the intake gaskets but then you'll have to use a sealant which makes the job harder to clean up next round. You can do the timing without removing the VC's, unless you have a leaking cam seal, then ideally you would want the VC's off so you can pull the bearing cap for the cam seal, not completely needed but the ideal way to do cam seals.
Malcolm99 is offline   Reply With QuoteReply With Quote
