Originally Posted by mark@eibach
Originally Posted by 4Runnin4Fun View Post
I had the same assumption, bottom clip to eliminate factory rake. I called Eibach and spoke to an engineer, he explained that I should probably use the second clip to eliminate factory rake and the third if you have added weight up front.
When and who did you speak to at Eibach? I called them 2 weeks ago and got this response...
When I spoke with Eibach they said a lot of folks with no added weight choose to place it on the 2nd clip right from the start and are very happy with the height. I on the other hand have an extra 220#going up front and said I will definitely need to be on the 2nd clip anyway. I asked, will I need to go to the 3rd clip because I want to sit right at 3"with all the weight, he said it will sit at about 2.9"with that weight on the 2nd clip.... If I go to the third it will effect the handling to much.
Mark, can you verify what clip to put the fronts on to get almost 3" WITH an added 220# bumper and 90# full roof rack? We're getting conflicting info from Eibach support.
Thanks!
