View Single Post
Old 01-12-2021, 04:23 PM
JH225 JH225 is offline
JH225 is on a distinguished road
Front sway bar bushings: poly bushings will run you ~$30 on Amazon, and will come with new brackets. Just pay attention to the sizing. Your 4runner either has a 29mm or 30mm diameter bar. Best bet is to measure it before ordering.
For a stock vehicle, sway bar links are sway bar links. The high end ones at autozone are $50 for a pair and have a hefty warranty.
Lastly: be careful with the bushing mounting bolts. The threaded hole is just a square nut that is tack welded to the inside of the frame rail. These often break loose. Just keep that in mind. Maybe you’ll get lucky!
JH225 is offline   Reply With QuoteReply With Quote
