Thank you guys for your responses! I wound up using the green wire in the driver kick panel that ties into the 25A fuse into the engine compartment labeled as seat heaters. Green wire ends at the IC4 and goes no further. Did the Relay swap from the Tow to the IG to give it power and have another relay on order to fill the tow spot.
Mission accomplished!
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
