View Single Post
Old 01-12-2021, 08:37 PM
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
King Shocks QUESTION!
Originally Posted by usdmej View Post
how did the ride height adjustment go? did you have to remove/replace everytime you wanted to adjust? how many threads did you turn / how much lift did you end up with?
i adjusted the height w/ the springs off the body as i swapped 550lb --> 600lbs springs. i also set the allen adjustment facing out so i can adjust the height later if needed. i believe you can adjust while on the truck, just let the A arm hang. i ended up with 6 turns on drivers side (1 turn for my weight) and 5 turns on passenger side.
strangely, with the trd pro bilsteins and CF 2".. my height was 23.75". now with the kings i'm at 23.5". but if stock is 20", am at really 3.5" over stock?
daytonaviolet is offline   Reply With QuoteReply With Quote
