View Single Post
Old 01-13-2021, 05:22 PM
Wild Thing's Avatar
Wild Thing Wild Thing is offline
Real Name: Doc
Wild Thing has a spectacular aura about Wild Thing has a spectacular aura about
Wild Thing's Avatar
Real Name: Doc
Great Visual Calculator for Wheel/Tire/Spacer Influence on Tire Position
Don't know about you, but I learn best when I can see something - not just read numbers. Just found this calculator which takes wheel, spacer, and tire size, along with wheel offset, into consideration and then shows the position of the original tire compared to the new set-up.
Shows height and width of the old and new tire positions, both vertically and horizontally. Shows the change in proximity of the top of the tire to the fender well and the change in distance from suspension. Even shows the projected change in speedometer reading from old set-up to new.
For this bonehead, the visual is really helpful. To some of you this may be old hat, but for the rest I hope this helps you as much as it does me...
Wheel Offset Calculator
Stock 2008 Driftwood V8 4WD Limited with X-REAS, est. late 2020. Build page to come...
Wild Thing is offline   Reply With QuoteReply With Quote
