Originally Posted by xtremewlr
V8 or V6? Makes a difference.
V8 - timing belt and water pump are #1 priority. 90k change interval and you do them at the same time.
V6 - not much more than fluid changes that I am aware of. Not sure if 04 V6 had head gasket issues or not but if it's running good now, you are probably OK.
Both will need to have the tcase regularly engaging 4WD to keep the servos working properly.
Valve cover gaskets aren't horribly difficult for either engine, so I would get that fixed or do it yourself soon. Do both at the same time either way. Use OEM Toyota stuff.
I paid $4700 for my 2003 with 280k miles on it and thought I got a great deal. So yeah, you did good no matter what.
V6! [emoji1417]
