It has been a while.
The 6112 on 650lb springs and the Icon 2.0 feel better with the heavier ATZ P 3 tires, stock size.
The Icon 2.0 softened after 10k and now at 13k, one has started leaking.
The Icon 2.0 without resi is great for road handling, crawling, and forest roads. But good pace through the desert obviously requires at least reservoirs.
Also, bought Eibach rear shocks as spares and tried them already (then put back the Icons, ran one long loop faster, now they leak so the Eibach have to be put on again).
With 1" Eibach spring, the Eibach shock only gives me 4" of down travel vs 5.25" for the Icon. So this is a huge difference. Also, the Icon is a little more planted on the interstate and in corners. Have not pushed the Eibach like I have the Icon in the desert--and I don't think I will.
I have not yet decided what to choose for the rear going forward.
