For a situation just like this, I would advise you put whichever 5100's you decide on the top perch, put on whichever springs, add spacers and wheel spacers aswell, and use the cheapest aftermarket LBJ 's you can get, the most expensive UCA, 35" tires and send it to the the mall.
