Originally Posted by Fiffa
Speaking of the spacers...
They were supposed to give me about 1/2" of additional lift up front, which should've still kept about a 1" rake. At the moment, all four fenders at ~39" from the ground, which seems odd. I read a post on here about someone questioning if the UCA bushings could add a lift, with the general consensus was that is could offer a slight lift because of the droop you'd get with bad old bushings, which I had, but this seems a little excessive. If anyone has input then it'd be appreciated! Well, off for the alignment!
The front did end up settling to ~38" after the alignment and some spirited maneuvers on the way home from the shop, which gives me a stance that I am more than happy with! No more rubbing with the 33's and no pinchweld modding!
