View Single Post
Old 01-23-2021, 06:28 PM
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
Originally Posted by Forum148 View Post
Hey Guys,
Went down the rabbit whole today on trying to figure out how to get more travel out of the rear of our trucks without going with a full long travel kit. I think I have found that you can just run Tundra rear shocks as replacements. Wondering if anyone has first hand experience doing so.
Along my studies I also ran into the FJ guys doing what they call "superflexy" set ups. They are not using direct Tundra shocks but different shocks that extend the overall length and travel of the shock in the rear. The Tundra shock is not as long as what they are doing so I am thinking it may work fairly easily.
Here's a link to the "Superflexy" thread:
superflexy on the cheap, or more expensive if you're into that :bigthumb: | Toyota FJ Cruiser Forum
My idea here is using a 11 inch or sub 11 inch travel shock. I'm Currently running Icon 2.0's w/ icon 2" spring so I was looking at the Tundra 2.0 Icon Shock or they also make a universal 11 inch shock that could be a viable option as well. Trying to figure out if I would need to switch my icon spring for the toytec one. Gears are turning any experience or advice is much appreciated
Cheers!
Good question. I assume the intent is to have better traction and stability on higher-rated, slow-going CO mountain trails?
Looks like an involved process. The Icon 2.0 has just under 9" of exposed shaft and is good up to 3" lift with overall length, hand measured, 24" and per published numbers, 24.5". Other shocks good to 3" have the same extended length around 24-24.5.
So you want 2" extra. But that means how much rear lift? 4" rear lift? What would be the minimum spring that can use +2" shock travel? I don't know. But any difficulties reworking the rear suspension for a 4-5" lift aside, what front lift are you going to have to match a 4-5" rear lift?
Even at 3" of total lift front and back you are robbing your front suspension from travel in order to give your rear suspension more travel. Yet our trucks flex better in the rear anyway.
Wouldn't the end result be a truck more capable to climb big rocks and ledges but not more capable (in fact, less capable) of coming back down said rocks and ledges? Would that not cause issues, like, in rolling it on an offcamber spot that was ok going up but is not ok coming down?
Just thinking aloud.
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
