Notices
View Single Post
Old 01-25-2021, 02:08 PM
jayhat's Avatar
jayhat jayhat is offline
jayhat will become famous soon enough
jayhat's Avatar
WTS: 4Runner stuff (WA in person only) - Maxtrax K9 brackets, ARB, Tire carrier +more
I am in Eastern WA and would prefer to sell this stuff locally. If it's a small item, I could look into shipping. Message me for any details or questions. Just going to link to my local Craigslist posts since I already have pics there.
K9 EEZI-AWN MAXTRAX MOUNT SET (2) - $40
K9 EEZI-AWN MAXTRAX MOUNT SET (2) - auto parts - by owner - vehicle...
K9 MAXTRAX Mount Set – Equipt Expedition Outfitters
This is JUST the 2 mounting brackets - no maxtrax mounting pins (those are sold separately) or Maxtrax boards. You should be able to use these to mount to any roof rack type or a multitude of surfaces.
Auto Ventshade 23071 Bugflector Dark Smoke Hood Shield 5th gen 4Runner - $25
Auto Ventshade 23071 Bugflector Dark Smoke Hood Shield 5th gen...
Great condition. Comes with the screws needed to mount. Will need to get some little stick on rubber bumpers to put on the hood behind this.
RAM Pod I Locking Vehicle Mount with 18" Rod and Socket Arm - $20
RAM Pod I Locking Vehicle Mount with 18" Rod and Socket Arm - auto...
Sturdy way to mount a tablet, phone, gps, or other device in your rig. Solid aluminum rod inside. Uses the bolt of the front seat and can be bent for proper orientation. If you happen to have a 5th gen 4Runner this is bent perfectly to be the most stable with minimal movement.
ARB ARB505 E-Z Deflator Kit 10-60 PSI Tire Pressure Gauge Rapid PSI - $30
ARB ARB505 E-Z Deflator Kit 10-60 PSI Tire Pressure Gauge Rapid PSI...
Like new condition. Sat in glove box and used once or twice.
Rigid Armor Toyota 4runner (1998-2020) Spare Tire Hitch Carrier - $400
https://kpr.craigslist.org/pts/d/pas...267034103.html
https://www.rigid-armor.com/shop/spa...toyota-4runner
Brand new and never installed. Was waiting to buy a set of new tires and wheels before I mounted this. Going a different direction now.
This carrier will now be released with a additional 2” hitch insert, in order to not loosen up the stock hitch. It carries a wobble free hitch insert and a 2-locking mechanism on the swing arm.
Drop down at 45 Degrees
2” Spare hitch
2000 lbs. rated toggle latch
.5 quick release pull-out pin
Hitch insert wobble free lock
Made from 8120 1/8 square tube
Weighs 35lbs
Max tire size 34”
Holds 100 lbs. arm strength
jayhat is offline   Reply With QuoteReply With Quote
