Originally Posted by nihkon
Just to add on to what Addison already said about projector retrofits.....
I installed the Morimoto Mini H1 setup in oem 99+ housings about 8 years ago. They're been perfect this whole time. I only had to finally replace one of the bulbs within the past couple of months. Of course, I went with a "cheap" bulb (Xentec)) for the replacement, and it only lasted a few weeks. I should have spent the extra bucks on Morimoto replacement bulbs, as the first set lasted 8 years! lol
Addison, with the Mini D2S, did you have to enlarge the hole in the back of the housing to fit the threaded portion? I thought I had read that the threaded portion on the Mini D2S has a slightly larger diameter than on the Mini H1.
Wow that's a great review about the long-term on these things. That's why you use OEM and quality parts in the first place! Great info, thanks for sharing.
I did not have to enlarge the holes. One thing I will say is that the actual threaded 'retainer' that threads onto the actual projector body is a slightly larger diamter than the ID that it is supposed to nest into on the back of the housings. I used my Dremel to remove maybe 1/8" so it would nest flush. But honestly I think you could just tighten it up as much as possible and then JB weld everything in place without even having to take that extra step that I did. This probably doesn't make sense until your actual doing this retrofit and have the parts infront of you. Lol
Originally Posted by Fishwerks
No doubt! If you sneak into the states to Moab or something let me know.
Thanks for posting the info on retrofits too, that's getting higher on my to-do list so it's good to know what has worked long-term.
Totally! I'm planning a Wyoming trip as soon as the borders open again. I am sure I'll be trying to line up with
NateMob
and some of the Sherpa crew as well. Would be rad for you to join us too!
