Originally Posted by gigajoe
Would that toggle switch fit in the other switch holes in the center dash or the row of switches below it?
Negative, it only fits the dimmer or blank next to it so I got creative. Quick and easy way is just pop your blanks off both and try to interchange.
If you run out of spots (like me lol) I’ve seen where someone relocated their dimmer behind the interior fuse door just sitting there inside. That would free up the other if needed but I didn’t like that route personally.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
