View Single Post
Old 01-29-2021, 04:25 PM
Carova Colton Carova Colton is offline
Carova Colton is on a distinguished road
Ok, so behind the glove box is an ECM that got wet. I sprayed everything down with WD and dried it all out. I hooked the battery to see what the dash lights would do now. They are stable like pre-start up but the information center says to put the shifter in park to start vehicle. The lever is in park. I had to manually depress the release (the little square on the bottom left side of the the shifter) to manually move into neutral to be towed but then moved it back once in the driveway. Does the ECM control this or is it another sensor like a crankshaft position or neutral safety switch? Or did I mess it up when I manually moved it for the tow? Is there something that I need to do to get it back to good?
Carova Colton is offline   Reply With QuoteReply With Quote
