Originally Posted by Signal
So I started the lift today, I got the rear out and I am trying to put the springs in without a compressor. I lifted the other side and it opened it up a little but not enough to get the springs in. I am now waiting on a spring compressor. I only need to compress it a inch.
I didn’t use a spring compressor. I just removed the lower shock bolts, sway bar end links and the lower end of the pan bar. While frame is held up, use a jack a lift up one end of the rear end, then the other end allows for the spring to come out. Install the spring and repeat for the other side.
