Originally Posted by luiszo
Hello everyone,
This is my first post and I look forward to learning from you.
Background:
Year: 2002 SRS
Odo: 180,000 (easy driving, no off road, family car)
Please help and I hope I did OK with this post.
You did great with the post.
My sway bar bracket poly bushings would make a similiar noise I had to regrease them. The side to side motion could be the sway bar links front and back not tight enough. I would check front Lca bushings rear uça and lça busing also.The best way to do this is get under the car and have someone push the truck up and down and put your hand on the bushing brackets you will here the sound muffle or you can spray lubricant on bushings one at a time and the process of elimination.
