Originally Posted by luiszo
Thank you!
OK I looked up images of UCA/LCA as well as bushings.
Question....can I replace the bushings only or the entire UCA/LCA, respectively, needs/should be replaced as a whole? Asking in advanced in case this is the issue. As mentioned on other replies I will complete suggested actions this afternoon.
Wow, it sure is great to not feel alone on this.
Thank you all.
No worries!
You can just do the bushings, but they may be a pain to get out. I was able to use the bottle jack method on 3 of the 4, but one had to be cut out because of the corrosion holding it onto the LCA. I used Whiteline bushings for the lowers, which were easy to get in, but I was also interested in these guys, too:
Strongflex Front Lower A-Arm Bushings 96-02 4Runner + USPS Flat - $105.05 : Sonoran Steel Fabrication LLC, Toyota Truck Parts
I hear the OEM bushings aren't as easy to deal with compared to these ones.
