Originally Posted by BobsTrail
I tried to use a soldering gun that takes 150 watts, if I try to use something that takes over 100 watts it shuts off. Under 100 watts is OK. Maybe your unit is close to the 100 W limit?
This ^. I'm pretty sure what you have plugged in is over the 100w limit. I doubt you can get an exact 100w draw from the plug. I'd bet it trips at a lower point.
I had a heater plugged in one time just to see if it would work and your video is exactly what happened. It'd work for a few seconds and then the light would go out.
