Originally Posted by 4Runner4Runner4
So I just want to make sure that I’m understanding the big picture here.
The very first two replies said to replace your MAF sensor and to check your transmission fluid level. You did neither, and opted to entirely replace your transmission. And while doing so, now you have been told that the transmission fluid level was markedly low...
Well, I’m happy that your problem is solved...
my understanding of his last update is that they did not replace the trans, they put it on a lift & found a leak & checked the fluid was low, which is what caused the problems. so it was low on fluid that caused teh problems & so far he hasnt reported back on how it drives with the correct fill level. trans wasnt changed from what i gathered.
& when i say 3.5qts i almost always put a "~" before it... which means roughly or about or estimated. ive seen 3-3.5 on pan drains & anywhere in between.
