Dash lights work (main dash lights not so much the individual warnings lights)? Front marker lights work? Both are on the same circuit.
Guessing you checked the fuse for continuity?
I don't think the other things you've done are related.
A 'bad' wire usually shorts out, hence checking the fuse first....
Reason: details
