Originally Posted by flyrv9
Another thing you can check is the gap around the top and sides of the door when closed. Compare it to its mate on the other side if it operates properly. Either the door is off or the latch assy is off. I think adjustment will be trial and error.
Yes. Page 5445 of the factory repair manual shows how to adjust the doors so you have even gap all around. There are pictures in the repair manual that show how much gap you should have.
Due to the weight of the door, you should have the dealer do any adjustment of the hinges, if needed.
