2004 white SR5 Sport 4wd/V8- Ripon WI 240k $4700
2004 T4R sport edition
White
Hood scoop
4wd & V8
240k
Timing belt and WP done at time of purchase with previous owner at 222,222
Has Scan Gauge II
Non smoker
Maintenance since ownership:
222,222
Timing belt and WP
Denso 3297 plugs (8)
Htp cabin air filter
Phillips low beam bulbs
Phillips high beam bulbs
Phillips fog light bulbs
Power stop k2422 drilled and slotted rotors all 4 corners
Power stop brake pads all 4 corners
Rear diff fluid changed
Front diff fluid changed
Brake fluid flush
Brake fluid reservoir replaced
Power steering fluid flushed
Duralast MAF sensor replaced (will provide my phone number for the lifetime warranty)
Washed with griot's garage/clay bared and waxed
HCF delete
Oil changed with mobil 1 oil and mobil 1 filter every 3500 miles.
Dash is has cracks in the material that's covering it, no crack goes through the dash. Currently has a removable carpet cover on it.
Needs a new exhaust 02 sensors/exhaust. Gets check engine light for p0175, P0171.
Currently rear hatch lock is frozen. Will disassemble and lube once it isn't -4 degrees out
4700 and I'll get it detailed before you pick it up or 4500 as is. (Just dirt/light pet hair)
Will run through the touchless carwash and upload pics
[B] 2004 Sport edition V8 Natty white-
Sold: 1999 T4R Limited Imperial Jade mica, 2017 T4R SR5P magnetic gray metallic
