5th Gen Accessorides Remote Start
Selling 5th gen 2011-2019 Accessorides remote start system for "G-Key" (not push to start vehicles). Nothing wrong with it, just switching to Viper system. It is plug and play and uses the OEM fob. Perfect for warming up or cooling down your 4Runner before you get in! $230 shipped
I contacted Accessorides regarding my key being programmed in the module. They gave me reset instructions so it will work on other vehicles.
MODULE RESET
- With the ignition off disconnect all connectors from the main module.
- Press and HOLD the button on the side of the module. Continue holding the button while plugging the two main black connectors in (the one with the thick wires and the 2nd largest black connector)
- Once the LEDs start blinking RED you can release the button. Plug the rest of the connectors back in to the module. Now the module is reset and you can redo the original programming procedure
Reason: Price drop
