Notices
View Single Post
Old 02-11-2021, 10:05 AM
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
cm-dc3 is a compustar brain
actually firstech.
i would keep this and add a long range remote or do drone mobile, i think you can change some option and turn this to a full alarm and remote start.
add a siren and starter kill relay and the digital tilt sensor.
might need to buy the web programmer and make an account, not sure it you will get full access to it.
when you first used this on your truck, you have programmed your key code for the bypass to work, its built into the brain. the older model cm 7000 and 7200 use a blade module or if doing the externally its a small box.
dc3 has the built in bypass, just need to have it flashed with the right firmware.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
