Originally Posted by shock003
I thought your battery sounded way too low.
I wonder if someone with a 3rd gen 4runner could do me a favor...
disconnect the neg cable from the battery and connect a 12v test light between the negative post of the battery and the other end to the negative cable just removed. And see if the test light lights up. and if you pull the DOME fuse - if the light goes out.
Maybe the DOME fuse is intended to work that way as opposed to telling me I have a short?
If this helps: I have a 2002 4runner Sport with a factory alarm.
It would save me from chasing something that may be as designed. If anyone sees this request....I may need to make a new posting directly related to this request. Thanks!
I would do it if I wasn’t so close to vehicle inspection. I don’t want to have all my readiness monitors unset. Someone with a 01 or 02 should do the test to have similar control systems.
