I have an 04 sr5 se
240k. (I know it's more than you want)
Came from North Carolina last June. This is its first winter. All stock except for HCF delete. Meticulously maintained but needs an exhaust/o2 sensors
2004 T4R sport edition
White
Hood scoop
4wd & V8
240k
Timing belt and WP done at time of purchase with previous owner at 222,222
Has Scan Gauge II
Non smoker
**Will wash then post pics**
Maintenance since ownership:
222,222
Timing belt and WP
Denso 3297 plugs
Htp cabin air filter
Phillips low beam bulbs
Phillips high beam bulbs
Phillips fog light bulbs
Power stop k2422 drilled and slotted rotors/new pads
Rear diff fluid changed
Front diff fluid changed
Brake fluid flush
Brake fluid reservoir replaced
Power steering fluid flushed
Duralast MAF sensor replaced (will provide my phone number for the lifetime warranty)
Washed with griot's garage/clay bared and waxed
HCF delete
Oil changed with mobil 1 oil and mobil 1 filter every 3500 miles.
Dash is has cracks in the material that's covering it, no crack goes through the dash. Currently has a removable carpet cover on it.
Needs a new exhaust 02 sensors/exhaust. Gets check engine light for p0175, P0171.
[B] 2004 Sport edition V8 Natty white-
Sold: 1999 T4R Limited Imperial Jade mica, 2017 T4R SR5P magnetic gray metallic
