Originally Posted by matoolie
Did you use the aftermarket mirrors from your first post? If so, how is the fit and quality of the mirrors? Thanks!
Yes, I used those aftermarket mirrors purchased off of eBay. They are okay, but fully aftermarket and not an OEM clone. They're still heated, although I have not yet tested that this works, and add signals and puddle lamps. Neither the signals nor the puddle lamps are OEM design, so those components are not interchangeable with OEM. In the end, they work, but they're not quite as durable (wall thickness is about 2mm vs 3-4mm for OEM). The painted shell was interchangeable.
Overall, they are not quite as well made as the OEM component, but you get what you pay for.
