View Single Post
Old 02-16-2021, 01:12 PM
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by BostonJon View Post
update here -
i cleaned the TC again to see if i could get a better indication of where the leak was coming from. after checking again, it appears that the top of the TC is actually wet with fluid and this fluid is seeping down the TC housing.
I remember reading some threads about people replacing a seal at the top of the TC where the 4WD shifter comes up through the transmission tunnel. this appears to be done from the interior of the vehicle. Of course, now I cant find that thread despite searching.
Would it be possible that my leak is coming from that seal at the top of the TC?
That's a fairly common area for the transfer case to leak at. It's done through the body on top. I think this is the procedure you're looking for: DIY/ How to Change 3rd Gen T4R Transfer Case Shifter Gasket
