you always bleed every brake pad change. when pushing the piston back, you also need to open the bleeder in the caliper and open the cover from the reservoir. that way, the fluid has a place to evacuate. if you did not do that, you might experience hard to push piston.
bleed it first and make sure to bleed all wheels and make sure the reservoir is always full, not going too low during the bleeding.
