You will need a new valve cover, the temp sensor should have a tab squeezed and pull straight off, maybe help it gently with a screw driver. That's pretty dark looking under that cover, keep up on the oil changes, I can't recommend engine flush as it's risky and the directions need to be followed to the letter, but it does work, I've used it from time to time for good luck on high milage 5vz-fe's for that reason.
