View Single Post
Old 02-19-2021, 05:08 PM
lockedlex's Avatar
lockedlex lockedlex is offline
lockedlex will become famous soon enough
lockedlex's Avatar
Originally Posted by jbtvt View Post
Gasket seat is painted? Weird. I've blasted tire beads with glass and they didn't leak after so wouldn't think it'd be a problem to blast. Yes, would avoid blasting inside with anything harder than soda or walnut shells. If DCM stripper won't take it off I doubt those will though.
Yes, I'm not a fan of what they did. It was painted from the factory, here's an example. Last time I opened it up, about 8 years ago, It was already peeling and I took a light sanding block but didn't really go to far into the seat/groove.
Good to know that beadblasting should be OK if needed. My plan is to try with Soda first... see how far that gets me for the outside and then go harsher if needed.. all the way to maybe an alum oxide or black beauty (?).
For the inside, I might just stop at "good enough" for fear of getting anything embedded, possibly messing up the Mg (?), or ripping of parts of the gasket groove seat. Worst case, I can just RTV it with whatever paint might be left.
Sandblasting Opinions Requested-gasket-jpg
2000 Limited V6 4WD | Factory Locker | 2nd Gen SC | NGK Spark Plug Wires | AEM Boost/AFM Gauges | Scangauge II | Sonoran Steel 1.2 Lift/Washer Reservoir | AirLift Rear Airbags/Wireless Compressor | 4XInnovations Front/Rear Bumpers | Schrockworks Skid Plates/Sliders | Warn 12k LBS Winch-Synline | LED Halo Driving Lights | LED "Satoshi Cover" Lightbar | Thermal IR Cam | BFG All-Terrain KO2 | Kenwood with Sirius/Garmin Nav and Surround-View Cam | Heated Seats | Lumbar Support | Blacked out Emblems TRD Badge | Rear Diff Breather Extension | LED Taillights | LED 6k Headlights | 120V Power Socket | Flipped Hood and Fuel Release | Rear Window Switch in Cargo Area | Custom FlipBlade Key | Warm White LEDs
lockedlex is offline   Reply With QuoteReply With Quote
