Originally Posted by SteelStacks
Just tried installing my sliding cargo tray the other day. Drilling was a pain. I managed to damage the threads in the bolt holes. Any idea on how I can fix this? Should I get a tap and die set to fix the threads?
So.. I damaged my threads as well. The sub-assembly holes didn't line up perfectly with the threaded holes underneath the sheet metal. Even using small drill bits I managed to instantly damage the threads.
How did you solve this? I imagine the
right way to do it is to use a tap of the correct size, but I'm not sure what that size would be. The bolt on the
Toyota website doesn't mention the size. Does anyone know how to figure out what tap to use for a bolt of unknown dimensions?
