Originally Posted by nissanh
I did the lower ball joints (OEM) few years ago and got about 25K miles done. Upper seems OK and no play there. I got upper ball joint boots to go with this fix.
I might go with poly bushings for pan hard bar. HArd to find the rubber OEM bushings for that. I see rubber aftermarket bushings to that.
What brand sway bars end links did you use? OEM are expensive as a lower ball joint!
I used Mstudt's extended links from the forum. Just remembered I did outer tie rods at the same time too, so something to consider.
