I was thinking 96-98 injectors since our 99+ are prone to failure anyways and offer no mpg or performance improvement that is measurable. My truck is a 99 model built in Oct 98, and the 96-2000 use the same TB, IAC, TPS, I don't think the average person would notice this unless they blipped the throttle from under the hood while its warmed up idling at 700-750rpm, I cannot recreate this hesitation when my idle is 850+ rpms
