View Single Post
Old 02-25-2021, 10:18 PM
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
It's hard to say what is leaking with so much oil spread out in the area, I would recommend using some brake cleaner and or some Simple Green or similar degreaser to clean it the best you can and then watch it to determine where the oil shows up as it leaks out.
Check it often because as the oil leaks out with the engine running the oil will start spreading from the cooling fan blowing the oil back into the same areas as it is now.
Report back as I'm sure others may have a similar leak.
2004 Limited V8
