View Single Post
Old 02-26-2021, 05:26 PM
TotalAutomotiveLV TotalAutomotiveLV is offline
TotalAutomotiveLV has a spectacular aura about TotalAutomotiveLV has a spectacular aura about TotalAutomotiveLV has a spectacular aura about
** Update on 700lb Coil Upgrade **
Current production lead time is 14-16 weeks
Part #58747-700
Part #58747C-700
FEATURES & BENEFITS:
- Adjustable coilovers yield 0-3.5" of front lift height
- Fully serviceable design allows for revalves, rebuilds, and an immeasurable service life
- Bolt-in design makes for an easy install into OEM shock location
- Increased wheel travel and vehicle specific valving provides unrivaled ride quality across a wide range of on and off-road use
- Extended Travel length requires installation of aftermarket front upper control arms
- Superior low speed control reduces body roll and increases on-road stability
- External reservoir to attain cooler operating temperatures during extended off-road use
- ICON's CDC Valve technology allows for 10 levels of high-resolution compression adjustability with the turn of a knob
- High quality ICON-engineered coil springs with higher spring rate included to better support added weight to front end
- Corrosion resistant CAD plated shock body with 7/8" shaft
- FK Rod End bearings provide extended longevity and minimal deflection
TECH INFO:
- Factory Wheels & Tires Fitment: Yes
- Recommended Aftermarket Wheels: ICON Alloys | 17x8.5 w/ 4.75" Backspace / 0mm Offset
- Recommended Aftermarket Wheels: ICON Alloys | 18x9 w/ 5" Backspace / 0mm Offset
- Recommended Aftermarket Tires: 33" x 11.50" (Larger Tires May Fit but Fender Trimming and Modifications will be Required)
_
TotalAutomotiveLV is offline   Reply With QuoteReply With Quote
