View Single Post
Old 02-26-2021, 06:00 PM
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
Look for damage or burnt traces on the circuit board behind the cluster, they are fragile and it doesn't take much corrosion or manipulation to sever a circuit, check for continuity from cluster plug to bulb connection.
Malcolm99 is offline   Reply With QuoteReply With Quote
