Banned
Real Name: Mark
Banned
Real Name: Mark
It may not be all that bad. Vacuum out all that mess, clean up rodent urine etc with isopropyl alcohol. Assess all the sliced wires. From the photo it looks like you can cut out the damaged sections of wire, solder in new lengths of wire, and heat shrink the soldered joints. Don’t crimp or use those quick heat splices, use real tin-lead solder and copper wire of the correct gauge. Do a good job. Test it all out and when satisfied reinstall the plastic sheath and use heat resistant tape to seal it up. Good luck.
