Originally Posted by Placemotorsports
Yes those are the ones that I got for the rears and I got KYB top pieces for the front struts off Amazon. So with the added lift in the front the rear will still look ok?
Should be fine. I used new 2007 FJ coils in the rear of mine when I replaced the XREAS. Had a slight stick bug stance but still looked fine. Easy enough to add small spacers later if you need to.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
