Originally Posted by 3bears
Been reading through this thread again, trying to decide, then I saw that you talk of using a panhard brakets. I was under the impression if a person went 2 inch they would not need a diff drop or the panhard bracket. ....only when you get to 3 inch and above.
so are you using either of them and were you told you needed to ?
FWIW, I originally designed the PCK for my 2" OME lift kit. (then made it accommodate taller lifts)
Don't believe the advertised heights of lift kits - the actual lift depends largely on truck build-out and typical load. My OME 2" was taller than that in reality.
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
