View Single Post
Old 03-03-2021, 01:47 PM
ej86923 ej86923 is offline
ej86923 is on a distinguished road
Originally Posted by calimobber View Post
You just have the regular system. Just need a remote for your year vehicle. Its kinda a pain to get to work. I always have issues getting it to work. Also I have ordered a remote that never worked for me. China makes alot of crap.
Here it is.
1. Start with the following conditions: you are in the vehicle
a. Key is out of the ignition
b. Drive door is open ( all other doors are closed)
c. Driver door is unlocked (other door locks don't matter)
2. Insert the key into the ignition (don't turn it) and pull it out.
3. Perform these steps within 40 seconds:
a. Cycle the power locks 5 times. Use an even pace and try
to go relatively fast.
b. Close, then open the drivers door.
4. Perform these steps within 40 seconds:
a. Cycle the power locks 5 times (same as before).
b. Turn the ignition to ON then back to OFF.
c. Turn the ignition to ON then back to OFF.
d. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should cycle (automatically)
indicating successful entry into programming mode. Return to step 1
if the locks do not cycle at this point.
6. Perform these steps within 40 seconds:
a. Press the LOCK and UNLOCK buttons on the transmitter
simultaneously for 1 second.
b. Immediately after letting go of the lock and unlock buttons,
press the lock button by itself and hold for 2 seconds.
Within 3 seconds, the door locks should cycle ( LOCK then
UNLOCK) once-- indicating successful programming. If
the door locks don't cycle, or cycle twice. Repeat steps
6a and 6b--this remote has not been accepted.
c. Repeat steps 6a and 6b for EACH transmitter that will
operate the vehicle. Including any old transmitters.
7. Close the driver door.
Thanks, I had figured it was that procedure which I have tried a couple times but haven't been able to get I to programming mode. Any certain tricks when it comes to timing of the sequences or anything?
Also I believe that there is another set of programming where you can have the doors lock and unlock automatically when you shift from park etc. I'll dig around and see if I can find a thread on that as well.
ej86923 is offline   Reply With QuoteReply With Quote
